Looking to replace the front struts on my 2014 Tundra. Is this easy to do? Any advise or how to is appreciated, Thanks Bruce
Odd, as at any setting, the total height uncompressed is the same.I dropped the lca completely as per YT video, the Bilsteins on the highest setting would not let me put it back in the hole, it's too long, tried prying, got spring close but not top threaded part. 1" from hole.
Sent from my Nexus 6 using Tapatalk
Odd my ass, you take a shock and extended it by 1-1/2 " top setting it ain't going. The lca is preventing it from letting it line up properly.
I have had no issues 3 times man, it is odd.Odd my ass, you take a shock and extended it by 1-1/2 " top setting it ain't going. The lca is preventing it from letting it line up properly.
Didn't try that, I'm old, sore and have 500.00 thankfully. I'll let the youngens put it on. Thx.Uncompressed the length, it is the same. When I swapped mine, I put the top in first and then used a couple pry bars at the bottom to muscle that part in.
Edit: Actually, in all honesty, I didn’t have pry bars. I used a couple of larger crescent wrenches as pry bars.
You people are the best, that's why love this forum. Thx.
You in Maine? I’ll do it for $300 and then you can get that alignment. Haha, no worries. I understand. I’m a bit younger. It took me a lot of trial and error and about 9 hours my first (and only) time. If I had $500 burning a hole in my pocket, I’d have hired it out. Unfortunately, my pockets have holes, and it’s not because all the money, LOL. I needed height on my last truck due to plow bottoming out. Thankfully haven’t needed to shell out on shocks again, yet.
Seriously, 9 hours?
Gdamn.
I think my 2010 first tundra it was about 2.5. Lol. I think with uca's and everything, including swapping springs on my 2017 it was about 3-3.5, using a bs spring compressor, while hungover.
No knocking.
Look guys, if anyone has issues, ask. More often that not, if someone up in here is in your area, and mechanically inclined, we all like to help, and meet other peeps.
You can look up service if you register with the Toyota owners website. You can see what has been done service wise.While I got some shit rolling, 2010 tundra. Notorious for blowing steering rack, just bought the truck. Putting Bilstein 2-1/2 lift on front, 305-55/20 tires on it. Got 76000 mi. on it. Hopefully it has been replaced or it is good. Thoughts. Thx.
In alll the cars I worked on the suspension o never had issues with the sway bar if both sides where of the ground completely decompressed plus assembled the suspension and installed and adjusted while decompressing springs always used like 3 of em though and tied them against the assembly in case one of those fuckers snapped.You absolutely need to disco the sway bar, so you're on the money.
And they will fit.
